Risograph GR 3750
  • cliffhangers
    • Feb 2010
    • 243
    Risograph GR 3750
    Risograph GR3750 display error T1 been help thanks in advance.
  • ntbann
    • Jan 2012
    • 631
    Re: Risograph GR 3750
    I searched CTN and it looks like it has to do with drum position.
    • jermyth
      Riso dude
      • Mar 2011
      • 441
      T1, main motor lock. The drum is still at position A after main motor has started or position A sensor doesn't detect the drum after 5 seconds after the main motor has started.
      Solution 1: Turn off machine. Hold reset button (on control panel) while turning machine back on and continue to hold until machine is done starting up.
      Solution 2: Possible bad or dirty sensor A. Clean out sensor.
      Solution 3: Possible broken, bent or missing "flag" for sensor. Try another drum if you have one.
      Solution 4: tie rope to machine and use as a boat anchor and buy a newer machine
      Good luck.
