RP 3700 Error T12-305
+ More Options
Posts
  • antoniovs
    • Nov 2016
    • 12
  • 20gaugeO/U
    • 557
    Re: RP 3700 Error T12-305
    Have the manual??? You'll want to have the manual when working on an RP. They are over engineered for what they need to do. Open the scanner clam shell and look in the disposal area to see what's happened. That upper door can be removed easily but you'll want the book for everything else in the machine
    • antoniovs
      • Nov 2016
      • 12
      I opened the scanner table and disassemble the master disposal unit, it was broken and the gears were not in the right position, I had to paste the unit right with expoy glue and set the gears in the right position based on the parts manual...master diposal unit.jpg
