ERROR S35-2074-2 in Comcolur 7050
  • Hanna
    • Apr 2019
    • 2
    I have ErrorS35-2074-2 in Comcolour 7050. Please help.
  • supermario
    • 21
    Re: ERROR S35-2074-2 in Comcolur 7050
    Cyan negative pressure tank sensor is the problem. The signal remains on.
    • Hanna
      • Apr 2019
      • 2
      Thank you how can we correct the problem.
      • midos67
        • Sep 2015
        • 6
        First uninstall the motor from the negative pressure tank then clean the tank (alone) with 1 gasoline then 2 paint thinner then last with 3 WD40 make sure you shake it and lesson to the ball inside it. Hope it works, please give feedback for others to benefit
          • 37553
          Hey grave robber, this thread is within 14 days of being 6 years old, dead and buried
          • midos67
            • Sep 2015
            • 6
            😅 I know, but I thought I should not let this tip go. I don't think it is buried because these error codes still exist with them Risos. The ink tanks are always a problem.
