Riso Gd9630
  • Joe Foe from Buffalo
    • 393
    [Error Code] Riso Gd9630
    Error S035-2087-04 thats related to Ink supply unit error The negatively pressurized tank ink sensor for K continuously remained ON
    for at least a prescribed amount of time During ink circulation pressure maintenance. I can chapter 11 procedure 2-20 drain K reset code 44012 reboot an machine will work all day many prints. Can even reboot machine. Error will not come back till it sits over night When boots up in morning.
    • 393
    Re: Riso Gd9630
    Put ink in this morning ran my sample test. Had operator run a job same code. Went in tech mode did nothing backed out of tech mode it ran. Rebooted machine same thing happened that happen today. I rebooted again an can not duplicate code no matter what I do or sending jobs.
    • duct tape
      • Jun 2009
      • 87
        • 393
        Re: Riso Gd9630
        All good. Possible cause main operator likes to when has a near empty ink puts a full one in so if she's not around no chance it runs out. Then puts almost empty back in to let it run out when she's running it. Told main operator to stop that let it run out of ink then put a full one in.
        • duct tape
          • Jun 2009
          • 87
          Re: Riso Gd9630
          Yes, run the ink till it’s out then change . Never take out and put back in, causes air to get in the system.NEVER do that.
