Just purchased a RP3700 with 3.5 million impressions. The vertical registration is very poor, sometimes off as much as .25 inch. Any help addressing this problem would be greatly appreciated.
Riso RP3700 vertical registration
jazz fan
Thank you for the reply. Are you talking about the load spring and the one-way spring. Do any other parts need to be replaced in conjunction with the other two such as load spring collar or shaft guide or the gear on the end of the timing roller shaft? Thanks again.Comment
Yes.If you can get the collar for the brake replace both of them for better registration.Also clean or replace the feed clutch if you can get one.Dont think the timing roller needs to be replaced at this time.Maybe by 5 or 6 million then i would be ready for that.Comment
jazz fan
What do you use to clean the clutch with? Should it be removed or can you clean it on the machine? I have ordered the two springs and I should have them soon. Will reply with the results. Thanks again.Comment
