problem with Creating master withRiso ME9350E
  • Luba
    • Dec 2019
    • 2
    hello !
    I have a problem with a Riso I just bought. It's a RISO ME9350e Model (two colors)
    When I want to create the master I press the green buttun for creating the master. then, there is a sound like like mechanical issue. and after I have a pannel with an error: T27-248.
    When I press the little green button on the right panel to open the Master, The same noise appears and the led did not lit (so I can't open the Master door...)
    It sounds like something jammed... ?
    thank you for your help ! and sorry for my english mistakes !
    Luba
  • Luba
    • Dec 2019
    • 2
    Re: problem with Creating master withRiso ME9350E
    Update !
    I managed to force the opening of the Master door. (nothing broke :-)
    I pulled the master trail, removed and reinstalled the Master roll.
    closed the door,
    everything is ok !
