want to know the difference between RZ220 and EZ220
  • IT Lover
    • Dec 2019
    • 2
    [Misc] want to know the difference between RZ220 and EZ220
    Hi experts. Plz help me. i have EZ220U. and now i have plan another one but i want to know few things. can i use drum of RZ220U in EZ220U? what are the difference between EZ220U and RZ220U? and EZ/RZ220U and EZ/RZ220UI. what makes the difference U and UI. plz explain. tnx
  • 20gaugeO/U
    • 557
    Re: want to know the difference between RZ220 and EZ220
    Can't use an EZ in an RZ or an RZ drum in an EZ. Mechanically they are are pretty much the same machine, it's the PCB's (main board, power supply and drum boards) that are different and inside the drum they changed some stuff to stop the ink from leaking in spots.
    An EZ 220 and EZ 221 drum are interchangeable so you know
    • Joe Foe from Buffalo
      • 399
      rz an ez drums can be made to work in one or other with a kit riso made. I have one. Call 716-832-4950
      • 20gaugeO/U
        • 557
        Yes you can convert an RZ drum to an EZ drum but then you can't use it in the RZ machine
        • IT Lover
          • Dec 2019
          • 2
          How to convert? plz explain... tnx
          • 20gaugeO/U
            • 557
            Open the RZ drum and replace the drum PCB and I believe ink detect board (and wire harness??? been to long) then you have a drum that will work in an EZ but not in an RZ
