RZ-220 Error codes
  • ldfrepairs
    • Oct 2012
    • 148
    RZ-220 Error codes
    Came across an RZ220 displaying error codes D04-560 & D17-237.
    Check the meaning of the codes and troubleshoot. Did not find any cut wires. Replace print cylinder with a working one but error codes remains.
    Just want to ensure that such an issue is caused by the Mech_Ctrl PCB before I order a new one because they are very expensive.
    drugstore-onlinecatalog.com
  • 20gaugeO/U
    • 554
    Re: RZ-220 Error codes
    Are you using generic ink and masters??? Seems odd both RF tags have failed
    • ldfrepairs
      • Oct 2012
      • 148
      no generic. ink and master are OEM.
      • 20gaugeO/U
        • 554
        Only time I've had an RF issue was on a new machine where the master roll sensor connector had popped out in shipping transport. You've already tried a new drum, have you tried different ink and masters from a different lot number? Had a few very low volume machines where the ink was in the machine for so long it made them change it out even though it was still 1/3 full...
        Otherwise cut tie wraps and reseat all connectors before ordering a new (different) board. They are old enough you should be able to find a used one
