Paper Feed Problems Riso EZ591
  • nprint
    • Jul 2020
    • 7
    Good evening everyone, I am having an issue where the machine pulls the paper in about 5" then stops and says jam.
    I was told its the timing but i am not sure what to adjust, i have the service manual. any input would be greatly appreciated
    regards
  • inutelkamo
    • Jul 2011
    • 143
    Re: Paper Feed Problems Riso EZ591
    Can we check the counter of the machine?
    Have you check the stripper pad? Pick up Rollers?
    • GreenTech
      • Oct 2020
      • 5
      regards
      jam code?
      • nprint
        • Jul 2020
        • 7
        I have 300K on the machine, new pickup rollers and stripper pad
        • nprint
          • Jul 2020
          • 7
          Originally posted by GreenTech
          jam code?
          J8 is what i see
          • GreenTech
            • Oct 2020
            • 5
            no feed at all or intermittent jams? J7 as well?
            suggest first to clean the registration sensors, probably covered with paper dust (pickup rollers and stripper pad good?).
            replacing the one-way gear at the timing roller assembly follows.
            • jermyth
              Riso dude
              • Mar 2011
              • 432
              First how many copies on the feed tires and sep pad? How many copies on the machine?
              Here is a RISO publication on jamming.
              Good luck.
              • nprint
                • Jul 2020
                • 7
                Good luck.
                total 800K copies on machine, feed wheels and pads replaced less than 5k ago.
                thank you for the pdf, I will see if i can figure out what the problem is. also noticed i am getting a fluttering sound?
                • 20gaugeO/U
                  • 551
                  Blow out the paper in sensors. Clean or replace the feed clutch. Replace the one way timing gear
                  • GreenTech
                    • Oct 2020
                    • 5
                    fluttering sound? check the shock absorber pad and replace if worn-out
                    • nprint
                      • Jul 2020
                      • 7
                      feed clutch was clean, one way timing looked good. cleaned paper sensor
                      • nprint
                        • Jul 2020
                        • 7
                        pad didnt look to worn, just a slight depression. I flipped it over hoping it helps.. doesn't flutter but still pulls paper 3-4 inches and jams
                        • 20gaugeO/U
                          • 551
                          Did you take the clutch apart and clean the red rust off the faces? Did you put it back together so it still free spins?
                          The timing gear looks like a one way timing gear, sometimes you just have to replace it
                          • nprint
                            • Jul 2020
                            • 7
                            I spent a good portion of the long weekend taking the whole thing apart. I went though the service manual and did all the adjustments.
                            got it running somewhat good, enough to get by but i think i need to replace the clutch it doesnt seem like its 100% working.
                            thank you for all your help
