Riso Ez 200 d02-532 & P98-28
  • Chlgmchjiru
    • Jun 2021
    • 35
    [Error Code] Riso Ez 200 d02-532 & P98-28
    I have riso ez 200ep to be maintained. When power on it showe d02-532 after soon p98-25 is disply. Plc anybody, anyone help me.
  • jermyth
    Riso dude
    • Mar 2011
    • 437
    Re: Riso Ez 200 d02-532 & P98-28
    The D02-532 code is incorrect print drum is used, incorrect drum code. Someone has put the wrong drum in. P(T)98-25 defective RF PCB, unsuccessful initial communication with RF PCB. This usually has to do with the drum RF board most likely because the wrong drum has been installed. Get a manual.
    Good luck.
    • Chlgmchjiru
      • Jun 2021
      • 35
      Dear my brother, there is two RF on this machine, Drum & master make unit. Which one will have faller?
      • jermyth
        Riso dude
        • Mar 2011
        • 437
        Like I said in my first post, the drum. Have you put in a correct drum? You need to get past the first code before tackling the second. UNLESS this whole problem started without anyone swapping drums around and just happened out of the blue (which I doubt). But even if, try a correct drum, easy way to figure out if it's the drum or something else. GET A MANUAL.
        Good luck.
