Diagnosing cause of thin black line on riso print from RZ370ep
  • ianmck
    • Sep 2009
    • 40
    Prints from the title machine have a single thin black line down them as seen in image. The line can also be seen on the master. The TPH has been cleaned and there's no visible damage or dirt. Is this a fault with the TPH or could there be another cause.
    Thanks for any help.
    Ian
    • 37422
    Re: Diagnosing cause of thin black line on riso print from RZ370ep
    If the master was generated by scanning an original, I would say that you have a speck of dust of lint on a mirror.
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      Slimslob is most likely correct, but to confirm before cracking open the optics go into test mode and print out a test pattern, mode 80 is a checker pattern.
      Good luck.
      • ianmck
        • Sep 2009
        • 40
        Good luck.
        Thanks. The checker printed without the line, so it looks like dust on a mirror.
