RISO SF9350EIIE
  • brunot
    • May 2012
    • 148
    [Error Code] RISO SF9350EIIE
    Hello everyone, RISO SF9350 EIIE constant error appears as soon as you turn on the device, error T01-537. After several on/off cycles, it disappears. Checked drum sensor positioning, tested ok. If you turn it off and turn it on a couple of hours later, everything is fine. Then the next morning, this error occurs again... and so on every day. How to get rid of this error? Thank you
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    The manual description says: The print drum is not in proper position. The print drum is not locked when the print drum is in operation. The clamp is not in proper position when the print drum is in operation (except at master removal).
    I suspect that the Position-B stop sensor is dirty or failing. Power off the unit and unplug. Removed the back cover and blow out the sensor. Probably need to blow out the whole back side if it hasn't been done before. Strongly suggest you get a Service Tech to clean it out or at least get a Service Manual so you can see exactly where that sensor is located before starting.
    Good luck!
    • brunot
      • May 2012
      • 148
      Noted with thanks.
      • brunot
        • May 2012
        • 148
        Hi, problem solved!
        I've cleaned the Main Motor Encoder, machine tested ok.
        Thank you.
