Riso RP3700 - Paper feed folds paper/Buckle fold
  • Cp31
    • Feb 2024
    • 8
    hello everyone,
    i am encountering an issue with a RP3700, and running out of ideas to try and fix it.
    upon paper feed, the paper gets folded, crosswise, on the top part of the page. it feeds, prints and ejects fine most of the time, but the print is folded. (intensity of the fold varies, from very light to very marked, sometimes feeding paper totally folded and thus not printing everywhere on the page)
    from what i researched so far, it seems to be a problem with the timing between the first and second paper feed area. happens with every drum, and apparead during the printing of a book (pretty heavy duty), machine was running smoothly until then.
    it very much looks like the issue on this thread : but the solution proposed there does not work...
    the first page fed is sometimes spared by the fold.
    there is no vertical position issue on the prints that do come out.
    - there is no physical obstacle or anything, i can run a piece of paper by hand without any issue.
    - i have tried to run standard paper with the paper width lever set on "card" (as advised in the other thread), no changes
    - tried every possible combination of the force and angle dials
    - from the manual, what i have found is that you can adjust the off angle for the paper feed clutch if you are getting too much buckle. i tried to adjust on different values (test n°481), no changes.
    - in the back, everything looks fine from what i can tell (screws, timing of cams, etc.). i found that the beak of the pf clutch was no longer engaged in its locking plate, i put it back, but no changes.
    - spinning the timing roller assembly ccw (by hand), i compared the movement on another rp3700 we have, i feel like it is a little looser. people using the machine have been unjamming paper in the feed area without using the little lever to release the rollers, probably damaging them ? could that be the issue ?
    other thing identified in the machine : the collar separator is very very worn out, needs changing, but i cant see how that would create this problem.
    wanted to know if you guys had any idea before i tried to change the rollers assembly (i have the spare parts, just a bit afraid of the mechanics and to mess up the timing). i am not finding much on this on the web.
    thanks !
  • 20gaugeO/U
    • 557
    RP's were over engineered POS machines released in 2002 and obsolete since 2010. You'd go out for one problem and find 2 or 3 other problems to go w the original. The 3 main drive gears would break and throw off the timing which was a pain to replace and realign everything. Sounds like maybe the 2nd paper feed timing isn't firing correctly??? Spring or sector gear type thing. Honestly don't remember much about them anymore because the Z line came along and worked sooooooooo much better. Good luck but I'd recommending finding at least a EZ591 or something much newer or less complicated. Even SF is on its 2nd generation so if you really need a duplicator time and money would be better spent on anything but an RP. If you have a 2nd one run it until it dies and move on.
    • Samat Belyi
      • Apr 2025
      • 1
      I have encountered a similar problem on the RP3700 - when feeding the paper, it sometimes behaves and folds slightly, as in a forced boucle. I checked the rollers, pressure, even tried replacing the feed rubber. Partially helped, but not completely.It is interesting that once found the service manual through an old archive, which at one time downloaded on GGSel - then I was looking for firmware for another device, and at the same time saved a few manuals “just in case”. I didn't think it would be useful for a risograph, but in the end it contained a useful feed scheme and error codes.
      Perhaps someone has had experience with this - I wonder if replacing the registration rollers helped or if it could be the sensor?
      • Cp31
        • Feb 2024
        • 8
        hello,
        im writing an update since i managed to fix the problem, although it kind of resolved itself and im not sure which of my adjustments did the trick.
        i did mainly three things :
        - reset the paper feed clutch timings (for each paper setting) to factory settings – they had been changed before i got the machine.
        - adjusted the sensor height for the elevator : figured i would have less pressure under the wheels if the elevator did not go as high.
        - i fed thicker paper in the machine (150-200g) for a few runs.
        after weeks of trial and error with the pressure settings, the machine eventually stopped folding paper. it runs fine now.
