Can I put a Riso rp3505 scanner on a rp 3105
  • carolscurriculum
    • May 2017
    • 39
    Can I put a rp3505 scanner on a rp 3105 I know its a higher dpi scanner but has anyone done this?
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Can I put a Riso rp3505 scanner on a rp 3105
    I don't think so. Could blow out a board. And I doubt the controller would understand the different scanner.
    Good luck.
    • carolscurriculum
      • May 2017
      • 39
      I fried the inverter in the 3105 and am having difficulty finding one. I had the lamps on and touched it lets just say it was a shocking experience. The lamp went out and they wont come back on.
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        I don't want to know why you were in the scanner with the power on. But I will suggest looking at a parts manual and compare part numbers with what you have. I have not seen a RP in years so I'm a bit rusty on what's all in that over engineered box of nightmares.
        Good luck.
        • tumnahi232
          • Nov 2022
          • 2
          Well it's a risograph animation - I know I can recreate my file to mimic the risograph style and such, but since I have access to a risograph printer I want to print them out so I can get the riso's texturing and colors. I'm just trying to figure out if there's a way to export them as a photo sequence for cropping each frame on a single page.
          I know the process sounds silly, but does that make any more sense?
          • tumnahi232
            • Nov 2022
            • 2
            I don't think so. Could blow out a board. And I doubt the controller would understand the different scanner. netgear login
            pikashow apk
