T98-6 FRAM checksum error on SF5130EIIU- Firmware needed?
  • GramPaBo
    • Jul 2018
    • 12
    [Electrical] T98-6 FRAM checksum error on SF5130EIIU- Firmware needed?
    Hello all - I am getting a T98-6 error on a SF5130EIIU- Serial number is 44102181 even after reset with 110 and 111
    From what I found in other posts the first thing I need to try is to reload firmware - is there an open safe site to get this from?
    And or any other advice Like is the next step the Main System PCB or something odd like the drum
    Thank you all very much in advance for your assistance!
  • 20gaugeO/U
    • 554
    Re: T98-6 FRAM checksum error on SF5130EIIU- Firmware needed?
    Reseat all the connectors and check that the clock / time is set correctly both in user settings and service modes. Firmware is up to 3.0.0 so what do you have on your machine?
    • GramPaBo
      • Jul 2018
      • 12
      hello all - was just reminded of my posting this- here’s the fix:
      Perform this memory initialization 1st before loading firmware.
      The latest firmware version corrects the T98-006 code
      Perform TM9874 to activate protected mode TM’s to initialize memory then:
      TM1198
      TM110
      TM112
      TM111
      TM1193
