RISO RZ Drum whistle noise on black ink.
  • Inko Press
    • May 2016
    • 11
    [Misc] RISO RZ Drum whistle noise on black ink.
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: RISO RZ Drum whistle noise on black ink.
    Never heard that before, but the no print on page could be several things. Since you are not getting an error code, I'd pull the drum out and see what's on the screen. Is there an extra master on the drum? Is there something under the master? If no to both, is the current master inked up? If the drum is not inking up and you don't have an error code, then something is up with the inking rollers and the ink detection antenna has excess ink on it. Possibly the one-way gear is failing and you have not gotten to the ink overflow antenna yet. But my experience you get an error code before no ink on prints. Look at the drum for the above and let us know what you find.
    Good luck.
    • 20gaugeO/U
      • 557
      Yep it's trying to draw ink and failing for some reason thus the dry whistle sound. When it stops whistling you'll have fixed your problem
      • Inko Press
        • May 2016
        • 11
        • Inko Press
          • May 2016
          • 11
          Thank you very much, i will check if it pumps the ink properly !! Best regards.
            • 37502
            I wonder, how old is the ink. If stored too long or at the wrong temperature the ink can slowly dry out and become too thick to be pumped easily.
            • Inko Press
              • May 2016
              • 11
              • 20gaugeO/U
                • 557
                There should be a date stamped on the end. Anything older than 2 years toss and start fresh
                • Inko Press
                  • May 2016
                  • 11
                  Hi all out there and happy new year!
                  I checked the drum, clamp movements and so on and it seems to be fine. I extracted the ink cartridge from the riso drum and cleaned the ink looking for dry parts. I pumped the ink cartridge with fresh black ink from inside, inserted the ink and started the machine. No whistle noise this time and everything working ok. I think it was dry ink on the cartridge or at some point.
                  Thank you guys for the support!!!
                  Best
