RISO SF5130 error code A06-403, paper feed tray is at the upper/lower limit position
  • drawstring_socks
    • Jan 2023
    • 1
    Hello! First time posting here. I'm an artist and I'm working with a RISO SF5130 EIIU which arrived at my studio a couple of weeks ago. It displayed the error code A06-403 on startup.
    I'm sure this isn't where you all would go for error info, but what I found on Printers-Copiers Servicing Reference Manual
  • 20gaugeO/U
    • 554
    Re: RISO SF5130 error code A06-403, paper feed tray is at the upper/lower limit posit
    The machine has pull out handles on the feed and exit side of the machine. My guess would be whoever moved and/or picked up the machine didn't use them and either stuck either the upper or lower limit safety switch in the process.
    The upper is the large white plastic cover that encases the feed tray lower button above the feed tires.
    The lower is the thin sheet metal piece that runs the width of the feed tray UNDER the feed tray. When you toggle either one you should hear the click click of the switch.
    Key in on those to start
