RZ 220UI
  • johngallowayiii
    • Jun 2025
    RZ 220UI
    Machine jams about every 5 copies for no reason. It is feeding up to the 2nd feed assy but then it acts like it never turns the timing rollers. any ideas.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Is the machine out of time??? Check one way on the timing and guide cam. Also check the clutch spring on the front of the T/G rollers.
    • 20gaugeO/U
      • 553
      Replace the second paper feed area 1-way timing gear. The updated part number is 612-02101-207 and has a red core instead of black.
      • johngallowayiii
        trying the one way gear now timing is not the issue and the spring is fine. will get back to you when the part comes in.
