My new used RP3700 has an TO7-001 error
  • Eskimudo
    • Mar 2023
    • 2
    [Error Code] My new used RP3700 has an TO7-001 error
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: My new used RP3700 has an TO7-001 error
    RP units are Old and a technical nightmare. I hope you did not spend too much or can get your money back, T07-001 is a communication error with the digitizer CPU.
    After some research, I THINK, that the digitizer is an editor on top of the scanner cover. Try unplugging it from the machine. It's possible that it is unplugged and that's causing the error. It's been years since seeing one of those machines. Did you see the RISO working in person before buying it? If so then something happened in transport.
    Good luck.
    • Eskimudo
      • Mar 2023
      • 2
      Good luck.
