RZ 390 H-errors
+ More Options
Posts
  • Artsmith
    • Jun 2025
    RZ 390 H-errors
    Can anyone tell me why a Riso RZ 390 shows H errors every time it's switched on? It asks for the whole set, 1 through 6, and then sometimes then it still doesn't want to print. I've used two different inks -- one with and one without the chip. Any thoughts?
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    May have a bad board in the drum.Can you swap drums to see?Sounds like it is not reading the RF tag from the ink.
    • 20gaugeO/U
      • 553
      Reseat connectors on drum PCB and reset Test Mode 117 (Drum Memory Clear) and TM 890 (RF Tag Data)
      A long while back we recieved a bad shipment of ink. The RF tags on the ink would randomly fail. New tube, mid tube whenever. You could take the tube to a different machine and it would code out.
