EZ221 Replace ink bottle message
  • ldfrepairs
    • Oct 2012
    • 148
    Replace ink bottle message keeps been displayed. Replace RF module. Worked for 1 week message came back. Any suggestion what could be causing the RF Module to fail?
    drugstore-onlinecatalog.com
  • VENRISO
    • Jul 2015
    • 72
    Re: EZ221 Replace ink bottle message
    Hello, you probably have to replace the ink pump
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      Another possibility is the ink antennas are out of position, or the one way squeegee gear is failing, but that usually gives you a ink over flow error code.
      You can test the ink pump in Service Mode. Also check the drum contacts both on the drum and at the machine.
      Good luck.
      • ldfrepairs
        • Oct 2012
        • 148
        Thanks will do the follow thru and update all.
        • 20gaugeO/U
          • 557
          There's a small screen filter inside the pump (have to pay attention to the curvature of the screen when reassembling). If it is colored ink it can get gummed up from sitting around and not being used. Doesn't usually happen with black ink but can if not being used much
