The feed rollers will sporadically, but too frequently, pick up several sheets of paper at the same time instead of just the one. Any ideas on how I can correct this.
Thanks for that. I found the two dials that adjust the angle and pressure of the stripper and advice in the manual to adjust the stripper head angle first. Will try these and see if I get a result, otherwise I'll have to consider a new stripper head. Thanks for the pointer.
Clean also the sensor that controls how fast the feeding table comes up.If the table comes up too fast then presses the paper under the feed rollers and under force they feed many papers.
Multi feeds are sometimes due to the table being too high. Lower it some and that might help if the angle adjustment doesn't do it for ya.
Just to let everyone know that the adjustments I made worked and I no longer get multiple feeds. Thanks for everyone's responses. The other solutions might come in handy further down the road.
Glad you are sorted and have told us what fixed your problem. Too many threads are left hanging with no solution. That is no help to anyone on this forum.
I buy paper in the box and this last time I got the same type and brand that I have been getting and now the printer does not want to feed. Checked all settings and you now have to hand feed it the paper. It will not feed single sheet or pick one out of a bunch out of the tray. on site shredding
