Riso RZ 230
  • msa4
    Riso RZ 230
    I Installed a new riso rz 230 error code p-96-569 display...I don't have the service manual for it .. any hellp??
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    You have to input the color information and the ink category in the machine.In service mode input 117,press start....then 890,start.Power off,then back into service mode and run 887.
    • msa4
      Thank you Mr. Kopyrtek how to enter the service mode?
      • risografist
        • 18
        1. switch off your riso.
        2. press at the same time left and right positioning button.
        3. switch on your riso, when the battons (2) is pressed.
        • Yetno.0103
          • 63
          P96-569 = Either The Print Drum Color Information or Ink Catagory Information Is Still Not Input
          Follow this instruction to Installing ur drum.
          1. Insert Ink Catridge to drum
          2. Press and hold down at the same time left and right positioning button and Switch on the machine
          3. Insert Drum to the machine press Reset key if error appear
          4. Enter test Mode 117 and start
          4. Enter test mode 890 and start (this test mode will copies the ink information eg; ink color, ink catagory, etc onto the print drum PCB
          5. Enter test Mode 887 and start (this test mode will pump ink from ink bottle to print drum) and drum will rotate and one page master will clamp to the print drum, wait until ur print drum stop.
          6. Switch off and on machine
          Thanks good luck
          • daredevildesign
            RZ Color Codes to input for drum inking
            Does anybody know what the Riso RZ Color Codes to input for drum inking?
            Example: Bright Red is #5
            Thanks.
            • Kopyrtek
              Copier Psychologist
              • Jan 2007
              • 407
              Check your messages triple d.
