RP3700
  • chairuch
    • Oct 2009
    • 10
    RP3700
    Any one know where to get rp 3700 master disposal belt.?
  • Joe Foe from Buffalo
    • 394
    I may be able to get them since I'm a Riso dealer. I'll check asap and let you know.
    • chairuch
      • Oct 2009
      • 10
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        Take one to the hardware store and find one that fits.Costs a lot less and will last a lot longer.
        • bigste
          • 62
          What you need is a place that stocks for the trade. Don't know about usa but in uk I'd go to a bearing stockist as they also stock belts and if they don't have it they get it next day.
            • 394
            Not available any more. FYI I have tried and searched high and low on other Riso's needing the same belts to get cheaper ones then the ones Riso sells and they do not last long since the OEM Riso ones are made of some weird rubber stuff that the ink doesn't effect.
            • chairuch
              • Oct 2009
              • 10
              Thanks, you guys for all your help
              I will try at hardware store first
              Thanks again
                • 394
                I would warn you customer the part is no longer available and your useing a last resort part. Other wise when it goes bad and it will very soon your name will be mud an they may refuse to pay for the part and service. Put the warning in writing also to be safe and make sure every one understands before and after the fact.
                  • 394
                  Call this place.
                  800-760-2078
                  • chairuch
                    • Oct 2009
                    • 10
                    Thank you Joe
                    I just order those belts rom him
                    Thanks again
