Riso Gr3750 drum compatible on gr3770
  • bcp
    • Mar 2008
    • 57
    Hi can anyone tell me if a drum from GR3750 can be used on a Gr3770. If so does that mean then using that drum non hd inks can be used? any info would be greatly appreciated
  • zx81
    • May 2009
    • 25
    they can, i use regular GR A3 drums on my 3770
    but according to GR tech bulletin 83
    ....New type of "Clamp Plate Base Ass'y" is installed on a new GR A3 Color Drum. When you install present GR Color Drum into GR3770, it is required to replace a present Clamp Plate Base Ass'y with a modified one to prevent clamp gear from being damaged....
    i have a mixture of drums, some with the new clamp plate assembly and some with the old type.. so far i have had no problems!!
    i can email you the tech bulletin pdf if that's helpful.
    • Kopyrtek
      Copier Psychologist
      • Jan 2007
      • 407
      zx81 is right.No need to change the clamp.Have seen old style and new style run with no problems.
      • bcp
        • Mar 2008
        • 57
        thanks guys - so I reckon then that non hd inks should be used with the GR3750 drum?
        • bigste
          • 62
          Yes you cannot use HD ink in a non HD drum so use std ink.
          • urwi
            Re: Riso Gr3750 drum compatible on gr3770
            Hi, I'm a newbie and I need to know if the contrary is possible, using gr 3770 hd drums on a gr 3750 riso printer ?
            Thanks !
