Riso RP3105 sys error T98-526, Please help!
  • SamTheCopyMan
    Please help! I dont usually work on Risograph, but a customer called with this error message: T98-526 sys error
    Anyone know what this one is and how I can fix it?
    Thanks! SamTheCopyMan
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Drum set switch is on but drum connection signal is off.May have a bad connector:usually see this on the drum side.Can try to turn machine off,hold reset button down and power back up.
    • kiwitechnician
      • Dec 2008
      • 54
      Go to service mode and check the drum signal. Have you tried the different or color drum ?
