Riso HC5500 Head Lines?
  • Capstone
    • 35
    #16
    Originally posted by Joe Foe from Buffalo
    Anyone know how to get the HS2000 scanner to be able to be used as a stand alone scanner. The HS2000 is sold by Riso and can be used with the HC5500's and rips but Riso has no info on being able to use it with out the 5500 and rips. I know Riso doesn't make it and a diriver must be available to make it possible as a stand alone.
    How is it interfaced to the HC? If its USB you might need a special driver but if its SCSI then you might be able to use a standard Twain driver.
