Riso 3770 - Close Scanner Table message
+ More Options
Posts
  • Southern Yankee
    • Mar 2010
    • 11
    We have a Riso 3770 that is showing the message "Close Scanner Table" even when the scanner table is closed. Unfortunately, this prevents the machine from operating. Any ideas of how to fix this? Thanks for any suggestions!
  • joelsa12
    • Nov 2008
    • 260
    check the switches that tell the machine that the scanner table is open
    • Southern Yankee
      • Mar 2010
      • 11
      OK...thanks. One thing I forgot to mention -- when you open the front door where the drum is, the green light does not come on. Maybe that's a result of the machine thinking the scanner table isn't closed, but I thought I should mention it in case it sheds light on a different problem. Thanks again for any help and/or feedback!
      • joelsa12
        • Nov 2008
        • 260
        It goes like this check switches, check fuse on ppower supply. If neither of those it is a board or broken wire
        • Southern Yankee
          • Mar 2010
          • 11
          Hi, folks!
          Sorry to be so long in posting this reply, but the problem turned out to be a fuse. Easy to fix, and it's up and running!
          Thanks again for the feedback.
