Riso gr3750 t1 error
+ More Options
Posts
  • M Rezac
    • Mar 2010
    • 17
    I am brand new to using a Risograph machine (I am running a GR3750). I recently changed out my color drum and proceeded to make a new master. During the process the machine made a number of clunking noises and then ERROR T1 popped up. When I push "reset all" it says "Clamp Error Remove Master Roll and Re-Install." I tried this and it doesn't fix the problem. I noticed there is a Cut Master Strip in the Cut Master Strip area, but I cannot remove it -- when I try to pull it out it just tears. Any help would be greatly appreciated.
    Thanks!
  • M Rezac
    • Mar 2010
    • 17
    Problem has been solved. I found a web post on how to remove the drum by unlocking the drum hook. Upon doing so I discovered one of the master removal hooks is broken -- now, does anyone know if you can still run the machine if this is broken? If I were to manually remove old masters before creating a new one?
    • RRodgers
      • Jun 2009
      • 1947
      Yeah, on a GR you can manually remove the master and make a new one. The RP's and later machines would usually "freak out" and not let ya do that.
      • totonicone
        Hi M Rezac,
        Before you make a new master, unlock the drum, pull it out, and remove the master manually, then make a nwe master. we have tons of GRs machine. lot of things will go wrong with GRs (if you print lots of copies like me).
