coh jp-5000
  • gamalmehdar
    • Mar 2008
    • 55
    coh jp-5000
    the problem with this machine is the language in the lcd panel change to japanes after shutdown the machine and stay about 5-10 minutes .
    i retern it to english but after shut down its retern again to japanes???
    how can resolvethis problem
    best regards
  • craig
    service manager
    • May 2010
    • 23
    I would bet your backup battery on the main board is bad, not keeping your new settings.
    • gamalmehdar
      • Mar 2008
      • 55
      were are the battery
      is the battery inside the eeprom IC .
      i didnt get any other battery on the board .
      what do you think the pins which shuld be connect the external battery on the IC.
      thank you very much
      gamalmehdar
      • craig
        service manager
        • May 2010
        • 23
        The battery should look like a big watch battery on the main board, not on an IC.
        • gamalmehdar
          • Mar 2008
          • 55
          in Ricoh jp-5000
          in the Ricoh jp-5000 duplecator i think there are no pattery on the board.
          but wreten on the eeprom IC
          M48T58Y
          its with battery.
          can you check please
