riso error code A-02-509
  • francois
    service manager
    • 32
    [Error Code] riso error code A-02-509
    my risograph keep gives error A2-5O9 did clean master sensor it feeds master on drum but cutter does not cut master have tested cutter its working
  • 20gaugeO/U
    • 553
    What model of Riso is this again?
    • francois
      service manager
      • 32
      hi it is a riso RZ200
      • 20gaugeO/U
        • 553
        There is an updated master loading sensor 444-43007-404. Also clean the drum screen area between the trail edge of the master and clamp assy (the area the sensor looks at when in home position). You do not want that area to be shiny (alcohol) like the master, use a cleaner that will make it dull like belt cleaner. Upgrade firmware to latest. On our RZ 220 it is V2.14.
        • francois
          service manager
          • 32
          thanks, it was the sensor on top of the drum. the m/c is worhing now
