Riso GR2700
  • maxmax
    • Aug 2010
    • 12
    [Error Code] Riso GR2700
    Hi
    I have an old Riso gr2700.
    It was working fine so far.
    But last week appeared an error code E11.
    Please tell me what's wrong regarding this error code.
  • LA TECH
    • Sep 2010
    • 91
    E11 - Pressure Control Motor Lock
    Displayed to interrupt the machine operation:
    1) If the pulse from the Encoder disc on the Pressure control motor
    has not been detected within
    100ms from the start of the Pressure
    control motor.
    2) If the Pressure centering sensor status has not been changed from
    ON to OFF (or OFF to ON) within
    5 seconds from the start of the
    Pressure control motor.
    • maxmax
      • Aug 2010
      • 12
      Hi
      please let me know that how release(unlock) the pressure control motor?
      Thanks and Happy New year!
      • joelsa12
        • Nov 2008
        • 260
        check the gear that the pressure control motor drives known as the pressure gear. these are know to break apart in the middle causing the motor to seize up. if the gear is good and turns freely give it a test mode 90 and see if that clears it up.
        • maxmax
          • Aug 2010
          • 12
          Hi
          Thanks for the your tips.
          Looks like gear is ok but how can I get test mode 90,what that mean?
          Thanks again
          • maxmax
            • Aug 2010
            • 12
            Thanks for your tip.
            I took the motor and cleaned it but there is still an error code.
            I think that I should replace it with a new motor, but it's hard to find the part.
            Do you have any souces on how get that part.
            Much appreciated
            • TONERINMYNOSE
              • Aug 2010
              • 114
              Max it sounds like u should call a tech but if you want parts or machines call rich at green office solutions (631) 860-4993, i warn you, working on these machines can cost you a bundle if you dont know what your doing.
              • ddude
                General Troublemaker
                • 473
                Good call- these are great boxes, but they are a different breed-simple, yet you need to know them to fix them. A good Riso in the hands of an inexperienced tech will end badly.
                2000 mockingbirds = 2 kilomockingbirds
