need help on my RISO rn 2030ui.
  • downhiller67
    • May 2010
    • 67
    good day!
    need help on my riso rn2030 ui, I was runnig about 500 sheets, but suddenly encountered jam, I removed the paper inside the drum unit, but still error occurs " AO7-418"
    paper jam, check paper feed area and press KEY, i did clear error in test mode. but still "AO7-418" occurs. new to riso.
    need your expertise on this matter.
    Thank you!
  • montana
    • Aug 2008
    • 393
    hi...the SM said:
    A07 418:the paper sensor was on at the start of the machine operation when the start button was pressed.
    i hope this help...........
    • downhiller67
      • May 2010
      • 67
      thank you for the reply.
      problem solved, I just cleaned the paper feeder sensor.
