HC5500 3kv S03-243 & S03-255
  • dara
    • Sep 2008
    • 26
    I have HC5500 new model with lifting wire.
    After starting up I get s03-243, after resetting the error code (tm: 5.12.2) the transfer belt unit comes down until the lift wire get loosen and I get error S03-255. Again when I rest the code and blok wire loosen sensor the transfer belt unit goes up and I get s03-243 again.
    I replaced lower pos. sensor and vacuum sensor and ORMC PCB and checked the wires still the same. Please what else I have to replace or look at?
  • RRodgers
    • Jun 2009
    • 1947
    I'd have to look up these codes to be sure what they are.
    • dara
      • Sep 2008
      • 26
      i know what they are but don't have the solution
      S03-243: the vaccum positioning sensor fails to activate when the belt paten operates.
      S03-255: lift wire is loosen. (when i block the sensor of loosen wire the TB gose up again).
      • qazqaz1970
        Re: HC5500 3kv S03-243 & S03-255
        hi,
        please how to enter in service mode on hc5500 riso
        • RRodgers
          • Jun 2009
          • 1947
          Originally posted by qazqaz1970
          hi, please how to enter in service mode on hc5500 riso
          Are you a tech? Why do you want in tech mode.
          • qazqaz1970
            thank's for reply,
            our school copier have error codeee x02-223 jam, but no paper jam,
            perhaps copier need to reset.
            please help us...
            • RRodgers
              • Jun 2009
              • 1947
              thank's for reply,
              please help us...
              I think I might help ya, just as soon as you start a new thread and don't hi jack someone else's.
              • qazqaz1970
                i start a new thread...
                http://www.copytechnet.com/forums/di...tml#post253761
                • nito710
