I am getting a problem with the master removal - they aren't being removed and I am having to do this manually. I notice the masters that are not removed are often town in the middle.
When I try and make a master I keep getting repeated T1 or T3 errors, occasionally changing to T16. All report "clamp error" with an instruction to re-install the master roll.
It occurs on 2 different drums, and is worst when I switch betweeen drums (though this might be in part due to a drum specific problem (see below).
Also one of my drums has become "loose" in that the main screen has a lot of play and as a consequence does not rotate smoothly but wobbles.
Any help welcome.
Any help welcome.
