wrong drum size
  • risomat
    • Feb 2011
    • 30
    wrong drum size
  • risomat
    • Feb 2011
    • 30
    • ddude
      General Troublemaker
      • 473
      Strange- GR(w) drums should work just fine in a GR3770, I think that the black drum would be a problem, due to the HD ink in the black, but color (w) drums should be interchangeable.
      2000 mockingbirds = 2 kilomockingbirds
      • risomat
        • Feb 2011
        • 30
        • ddude
          • 473
          Yes, since paper size is different, the problem may be a switch setting. If you have a working color drum, remove the front cover and look at the bank of switches on the drum board- make the non-working drum switches match the working drum, you should be okay.
          • bigste
            • 62
            A GR colour drum will fit the 3770 but the black one won't unless you change the dip switches on the drums setting card. I would guess your problem lies with that card or the wiring to it. I had similar problems in the past. As it is same for 2 drums if they are both colour drums it could be the plug and socket that connect the drum to the riso.
            • risomat
              • Feb 2011
              • 30
              gotcha!
              thanks ddude, changing the switch setting helped.
              color (w) drum setting (us): R8 off, R9 off, R10 on, R11 off, R12 on, R13 off
              color (w) drum setting (europe): R8 off, R9 off, R10 off, R11 off, R12 on, R13 off
              black (w) drum setting (europe): R8 off, R9 off, R10 off, R11 off, R12 off, R13 on
