Paper Feed Problem - riso gr3750
  • alfasud
    • Apr 2011
    • 63
    Paper Feed Problem
    Do not turn the clutch shaft pickup
    does not seem to reach its current pulse.
    Help me.
  • ddude
    General Troublemaker
    • 473
    Carfully watch the shaft that the feed tire is connected on using a torch or other light source to ensure you can detect movement during feed operation- do you detect the shaft turning? If not, you may have a faulty clutch. If the shaft is turning, then the one-way bearing is slipping or is on reversed.
    2000 mockingbirds = 2 kilomockingbirds
    • alfasud
      • Apr 2011
      • 63
      The tree does not turn.
      Translated by google
