Pickup - feed riso gr3750
  • alfasud
    • Apr 2011
    • 63
    [Electrical] Pickup - feed riso gr3750
    I do not seem to get the 24 volts to the magnetic clutch on the axis of the clutch. It is controlled by a sensor?
    (Translated by google)
  • joelsa12
    • Nov 2008
    • 260
    adjust the stack switch in the paper feed unit. it is behind the green dials where you put the paper in. It will cut power to the clutch.
    • alfasud
      • Apr 2011
      • 63
      I already tried this, but does not work. It seems no power to the magnet that the two impulses to withdraw the paper. The shaft of the clutch is not spinning.
      (Google translation)
      • Chuck29620
        • Aug 2009
        • 31
        Re: Pickup - feed riso gr3750
        How did you resolve this issue? I have the exact same problem.
        • Chuck29620
          • Aug 2009
          • 31
          Never mind, I fixed it!
          • alfasud
            • Apr 2011
            • 63
            No, I sold the car as spare parts
