Risograph RA4300
  • SHuizing
    • Jul 2025
    Risograph RA4300
    I recently bought a 2nd hand Riso RA4300 from 1993. I worked when the guy demonstrated it to me, but when i got home there was a problem with the press roller. The hook thing doesn't really get hold of the lever thingy and the machine gives a E31 for jammed paper. I'm pretty handy with tech stuff, but I'm in way over my head Do any of you have some experience or tips for this problem?
    Also this is a video of the back end:
    Thank you!!
  • Iowatech
    Not a service manager
    • 3930
    There should be an adjustable bracket holding the lever down, try adjusting it downward a little bit. Ideally, when the hook is at the top of it's travel, there should be about a millimeter of space between the hook and the lever. Be careful, there's a really strong spring attached to the lever.
    Also, the solenoid that controls the hook is adjustable - when you hold the plunger in, the hook should totally engage the lever except for about a millimeter.
    Finally, check the connector for that solenoid with a meter while flexing the wires, they sometimes break.
    • SHuizing
      Thanks for the tip!
      • RRodgers
        • Jun 2009
        • 1947
        Everything he said.
