gr3770 slide
  • risomat
    • Feb 2011
    • 30
    gr3770 slide
    we can't release the slide/print cylinder handle (no drum inside at the moment). the green button isn't working. any ideas how to relase the slide?
  • risomat
    • Feb 2011
    • 30
    solved.
    • risomat
      • Feb 2011
      • 30
      new problem, can't load a drum into the machine anymore.
      the slide (without a drum) slips in and can be manually released, but the slide with a drum stops a little bit before the locking.
      might be a sensor problem, but which one?
      any help would be appreciated, thank.
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        Sounds like the drum cam is not aligning with the drum. You need to rotate the cam in the machine to the correction position for the drum to lock into place. Two ways to do this, 1st with TM 61 and watch the cam rotate to the correction postion to align with the drum shaft. 2nd use the drum rotation button on the PCB in the back of the machine.
        • joelsa12
          • Nov 2008
          • 260
          third have your left hand clicking the drum set switch, push the green button with your right hand and quickly move your right hand to the power switch. you will be watching the drum chuck in the back of the machine. before it gets almost to the point where the drum chuck is supposed to be turn off the power. it should stop right where it should be so you can slide in your drum. if you miss it the machine will error code hold down the reset to clear the code and try again. should take 1 min good luck!!!
          • risomat
            • Feb 2011
            • 30
            thanks for you quick reply.
            <del>but what is tm 61? testmode 61?</del>
            tm 61 didn't solve the problem.
            • risomat
              • Feb 2011
              • 30
              wtf! it worked.cool trick.
              you made my day! thank you very much.
              • joelsa12
                • Nov 2008
                • 260
                was that me making your day? if so glad i could help.
                • risomat
                  • Feb 2011
                  • 30
                  yes, you, joelsa12! thank you very much. the machine is working again.
                  • ddude
                    General Troublemaker
                    • 473
                    Wow, I learn so much just from watching you guys here-Hats off to joesla12! If I could rep up I would, and thanks to jermyth as well- my thought was a simple hard reset, but you guys know this equipment well-I am glad to be a member here.
                    2000 mockingbirds = 2 kilomockingbirds
                    • risomat
                      • Feb 2011
                      • 30
                      thanks for sharing all your knowledge.
                      maybe it's time to declare: a kind of a open source knowledge system works best.
