Streaks on prints
  • benoitv
    • Aug 2010
    • 18
    Streaks on prints
    Hello,
    My Riso RP3700 often makes vertical streaks (perpendicular to the printing / feeding direction), especially on light prints.
    It does not make it with every drum, but mostly with my blue and black drums, almost always at the same place. It's generally visible in light areas.
    at first I thought it could be the TPH, but as it is always on the same spot, and perpendicular to the print direction, it must come from somewhere else. The master doesn't look wrinkled.
    Thank you very much for your help!
    Benoit
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Check the optics. Have had to replace the scanner sponges to keep dust out on serveral RPs & RNs.
    • benoitv
      • Aug 2010
      • 18
      thanks for your reply. I forgot to mention that I only print from files, never with the scanner so it must have a different origin.
      Benoit
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        Hum...maybe a ink transfer issue? Any ink leaks on your drums? Check your timing roller, impression roller and exit belts for ink.
        • benoitv
          • Aug 2010
          • 18
          Hello,
          I did check, there is no sign of ink leak. the streaks are very thin and white, like lines. That makes me think there is a problem on the master itself, but I don't get why it makes it only on one drum and ocasionnaly on the other one, nor why these lines are always on the same location!
          Benoit
          • benoitv
            • Aug 2010
            • 18
            Problem solved!
            Strangely enough, it was coming from a glitch with the screening. If I use a "classic" screening the lines disappear!
            Benoit
            • RRodgers
              • Jun 2009
              • 1947
              Originally posted by benoitv
              Problem solved!
              Benoit
              I was going to recommend to try an internal print (the one to get the ink out of the drum would probably work) but I'm glad you got it sorted.
              • johnrheznik
                Riso image error
                hello there try to focus on the said drum maybe the ink squeegee have foreign objects stacks or your ink motor supply is not working properly.
