Standard SD 450 Error SC 06-00
  • xxmandingoxx
    • Jun 2011
    • 61
    [Error Code] Standard SD 450 Error SC 06-00
    was running fine yesterday after it was repaired, went to go run some copies and it shot out 2 then coded out, if i take out the master roll / then the eject box / then the drum and put it all back in while the machine is off it will pass a few more copies then do the same thing again
    so if anyone knows what this code is or knows how to fix it lemme know lol
  • yakyitz
    • 245
    Pressure plate does not move from home to the master eject ready position
    The pressure plate does not reach the master eject ready position after it has left home within 3 seconds after the pressure plate motor on signal is generated.
    Pressure plate does not return to the home position
    The pressure plate does not reach the home position within 6 seconds after the pressure plate motor on signal is generated.
    Pressure plate does not move to the compression position
    The pressure plate does not reach home while traveling from the master eject ready position to the compression position within 6 seconds after the pressure plate
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
