RP 3700 problem.
  • jazz fan
    • Jun 2025
    [Error Code] RP 3700 problem.
    Made a master on RP 3700. The elevator did not start upward. Machine sounds a beep and displays error TO2-404. After resetting both by reset button and turning power switch off & on, the same thing happens. Any suggestions?
  • 20gaugeO/U
    • 553
    Re: RP 3700 problem.
    1st - Blow the dust off the sensors dealing with the feed table.
    2nd - Remove drum and take the front machine cover off. Either there is a broken wire on the harness leading to the elevator motor or one of the small gears inside the elevator motor is broken. Can't order just the gears, have to get the whole motor assembly I believe.
    • inutelkamo
      • Jul 2011
      • 143
      Check sensors.. blow paper dust away..
      • jazz fan
        Thanks for the info. Cleaning the sensors didn't help. I cleaned the motor and unplugged and replugged the wiring harness and it worked fine. Thanks again for the help, it is greatly appreciated.
