Is it possible to use CR ink in a GR machine if transferred into GR tube?
  • ianmck
    • Sep 2009
    • 40
    Is it possible to use CR ink in a GR machine if transferred into GR tube? Are they the same ink in diffeent containers? The compents on the tubes indcates the same materials but it is not clear if the proportions they are mixed in is the same.
  • gillje
    • 143
    Re: Is it possible to use CR ink in a GR machine if transferred into GR tube?
    Another printer I know did this exact thing and it worked fine... I recently got some tr ink that I was planning on trying to use in a gr tube.
    • ukyo
      • Aug 2008
      • 51
      Yep! It's very possible.All Riso inks are compatible with other Riso models..The problem is that you have to transfer it manually.
      • mikadonovan
        • May 2008
        • 2931
        I'm not so sure about ALL the ink. I think the HD ink is different chemistry.
        NEVER ASSUME ANYTHING
