RZ220 Replace ink bottle
  • LennoxD
    • Sep 2011
    • 82
    Any suggestion on how to solve constant replace ink bottle message. Would replace with new ink cartridge and after about 50 prints replace ink bottle message would show.
  • 20gaugeO/U
    • 553
    Re: RZ220 Replace ink bottle
    Upgrade firmware to latest. V 2.14
    Get a new bottle of ink from a different lot number. Bad plunger seal or RF tag from old (years old) ink tubes that were found in the back cupboard.
    Otherwise going into the drum for inking motor, squeegee gear or something else.
    • duct tape
      • Jun 2009
      • 87
      I've upgraded all of my EZ-RZ machines, they still do this . Some machines do it worse than others,found no cure yet.
      • jermyth
        Riso dude
        • Mar 2011
        • 439
        How many units are you having this problem with? Both RZ and EZ? Have you checked and tried different lot numbers of ink? Was all this ink shipped at the same time (gotten damaged in shipping?)
        If you are sure it is not the ink, then it's something in the drum(s). One-way squeege gear, ink pump, ink ant. board. or drum connector are possibilities.
        • 20gaugeO/U
          • 553
          Is it genuine RISO ink?
          • LennoxD
            • Sep 2011
            • 82
            Genuine Riso inks. Yes tried inks from different lots. I also replaced the owc gear.
            • jermyth
              Riso dude
              • Mar 2011
              • 439
              Ok...let see if we can seperate the problem. It is either the drum, ink or machine. From the answers you've given, lets say it is not the ink. Have you tried swapping out an "erroring" drum with a good drum? Then try the "errored" drum in another machine?
              • duct tape
                • Jun 2009
                • 87
                I've tried all of that, you can swap out the ink from one machine to another,they run fine till they really run out of ink. I also do this with the masters, they do this randomly too.
                • 20gaugeO/U
                  • 553
                  As for the masters message, open the master making unit, loosen the two screws that hold the left side master roll flange that has the RF tag reader. Gently tap the RF tag reader assy with the handle of your screw driver and tighten down screws in the center the openings.
                  As for the ink I've only run into an occasional bottle that was usually found in the back of a customers storage spot and it would be stamped 2007 or something old like that. Or had been dropped on the switch ribs on the side of the bottle. Usually at a low volume location does this occur at.
                  Are you/they storing it cap down? I don't run into as many of the "old air pockets" calls as I used to on the old RA/GR's.
                  • bravo alpha
                    • Sep 2011
                    • 10
                    I had also that problem w/c is a headache to me recently. We replaced the ink with differrent batch number NG. Next is the inking hose then the ink pump unit and lastly the system pcb.
                    • RobertMartin
                      I agree with 20gauge he say right to solve your problem
                      • JeffS
                        • Jun 2009
                        • 5
                        I have run into this problem a few times. Every time I've run into the problem it is the inking hose running from the ink tube to the inking motor. Give the hose a squeeze and see if it's very soft. I have had one hose with a small split and wouldn't feed ink due the the air leak and two that were just collapsing under the vacuum of feeding ink.
                        Hope it helps...
                        • inutelkamo
                          • Jul 2011
                          • 143
                          invest for trade in... :0
                          • Joe Foe from Buffalo
                            • 394
                            All replies I are good and I have seen first hand. One of the replies is you issue check and recheck.
                            • berryna
