T02-400
  • paul the printer
    • May 2010
    • 27
    [Error Code] T02-400
    need help pretty desperately, riso rn2550 has code T02-400 saying push reset button which doesn't fix problem, half way through job, all the techs in adelaide are on xmas holidays, really be grateful for any help.
  • BoBa
    • 35
    Re: T02-400
    Error type T02 [Elevator motor lock]
    T02-400 Both the upper and lower limit sensors were blocked at the same time.
    !!System Error!!
    Press Reset Key
    • paul the printer
      • May 2010
      • 27
      Re: T02-400
      boba, have already tried that, it doesn't work, thanks you for your thoughts.
      • jermyth
        Riso dude
        • Mar 2011
        • 441
        Re: T02-400
        Have you tried turning it off, then hold the reset button while turning it back on?
        • 20gaugeO/U
          • 557
          Re: T02-400
          Blow the dust off the lower limit sensor in the back of the machine. Otherwise one of the small gears inside the elevator motor case has broken, or the two white wires running to the elevator motor assy has broken.
          • paul the printer
            • May 2010
            • 27
            Re: T02-400
            thanks jermyth, worked like a charm, but now have new problem i hope you can help me with?
            after about 500 run, a big blob of ink is coming out from under the clamp on the drum, i am running at the lowest ink possible, the prints are always very dark,
            is the machine running too much ink, or could there be something wrong with the drum? hoping you can help.
            • jermyth
              Riso dude
              • Mar 2011
              • 441
              Re: T02-400
              Two possible problems with the ink blob. 1. Need a new impression roller. It has gotten warpped over time and use and is stressing the drum. 2. Drum has blown the ink blocker under the screen, drum needs to be repaired by a tech.
              It is possible that both problems are happening too.
              • paul the printer
                • May 2010
                • 27
                Re: T02-400
                thanks jermyth, it has to be the drum, i put a colour drum in and that worked alright.
