FR -3950 Alpha is showing T-15 service code. How to fix it? It stop on the master
+ More Options
Posts
  • canppuci
    [Error Code] FR -3950 Alpha is showing T-15 service code. How to fix it? It stop on the master
    How to fix t-15 service code on Fr-3950 Alpha Riso machine?
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: FR -3950 Alpha is showing T-15 service code. How to fix it? It stop on the maste
    This is an error for the scanner unit. The image scanner is not detected or not released from the Home Position Sensor. You can try turning off the machine. Then push and hold the reset button while turning on the machine back on. If this does not clear the error or it comes right back then something is wrong with: a. the scanner motor, b. the home position sensor for the scanner, c. drive from the motor to the scanner (belt or gear bad/broken).
    Good luck.
