GR3770 image position on master
  • sscottsr
    • Jun 2025
    [Misc] GR3770 image position on master
  • jermyth
    Riso dude
    • Mar 2011
    • 439
    Re: GR3770 image position on master
    Something might be up with either the SC7700 or the image procssing PCB. See if happens with scanned images, if it does then its something in the machine (image PCB?) or not then something with the SC7700 or even software related.
    Good Luck.
    • sscottsr
      I should have thought to try scanning before, but it doesn't help anyway. I made a master and then without touching anything made another master. The second was "behind" the first by nearly 3/8 of an inch. So it appears that it is not software or SC7700 related. Any other ideas? Thanks.
      • jermyth
        Riso dude
        • Mar 2011
        • 439
        Check the write motor, the pulleys and the belt that drives the write roller. Also disconnect and reseat ALL the connectors on the Image Processing PCB & the TPH Power PCB.
        • mikadonovan
          • May 2008
          • 2931
          On the end of the write roller is a belt driven pulley. Remove the belt and tighten the allen screw holding it to the shaft.
          NEVER ASSUME ANYTHING
