Duplo DP-M400
  • hussain
    • 28
    [Misc] Duplo DP-M400
    After dis-assembly of Drum gear I assembled and run the machine. I noticed the printing margin is about 1cm down from the feed direction. I shifted the Center position sensor and this made a small correction. I changed setting of Help mode67
    also and couldn't corrected. please share your ideas if you had faced this problem.
    regards
    Ahmed/Maldives
  • hussain
    • 28
    Re: Duplo DP-M400
    i hope somebody will come up with tip.
