I'm having a separate issue for another GR3770 that I work with. Initially it was printing 3/4 of my image area before a loud 'clunk' would happen, so it would spit out the print with the last part of the image being cut off. I figured out that this was being caused by the Hook Lever slipping off the Pressure Lever 3/4's into the print.
I adjusted the spacing between the 2 levers and now I am facing another problem, the paper is misfeeding- it will feed a sheet a bit more than halfway in before it stops. So most of the sheet has entered the machine but it hasn't totally cleared the first paper feed area... Perhaps this video illustrates what's happening to a keener eye
What's the problem here? As always any advice is much appreciated!
